November 3, 2020 at 3:02 pm
Troe
SubscriberI can't seem to find where you import a s-parameter model into Circuit for Nexim simulation, can someone help me? I have been using ECAD to bring things in but now I need to import a .s4p directly. Thanksn -
November 5, 2020 at 11:50 am
VivekKamble
Ansys EmployeeHi, nYou can import S2P file into results and then do HFSS-Circuit co-simulation.nPlease follow the steps to import SnP files into HFSS, Here is the link of previous post which you can refer, nfor HFSS circuit Co-Simulation, Please visit our youtube channel, nhttps://www.youtube.com/watch?v=wa6HlTj1ecAnhttps://www.youtube.com/watch?v=SGirQwXnDPY nBest regards, nVivekn
- The topic ‘Importing s-parameter model into Circuit for Nexim transient analysis.’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1231
1118
1015
