December 17, 2024 at 1:15 pm
fatmaburcu.soylu
SubscriberHello everyone,
I have a question about importing geometry from CATIA V6 to SpaceClaim. I need a clean geometry in order to mesh it properly with using watertight geometry workflow. First, I cleaned all small surfaces and gaps in CATIA. Then, I exported the geometry in stp format. When I opened this exported geometry in SpaceClaim, the quality of the surfaces are not good enough. Some of the surfaces have some self-intersections and others have some gaps. These gaps aren't recognized when I use the "Open-face" feature. To fix it, I need to seperate the problematic surface first then I need to sew it again with using "Sew" feature. Also, I need to divide the self-intersected surfaces into many small surfaces. I want to prevent this problems. How can I import or export the geometry with high quality surfaces without applying these steps.
Thank you.Â
December 18, 2024 at 7:32 am
Keyur Kanade
Ansys EmployeeYou can read CATIA file in SpaceClaim. You can use option on SpaceClaim reader as shown below in FIle -> SpaceClaim Options panel.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
5704
1896
1419
