December 26, 2018 at 6:47 am
ashiadarsh
SubscriberHi everyone,
I am trying to import coordinate points to Design Modeler to get a curve. I have created a text file which contains 5 columns: Group ID, point number, X, Y, Z coordinates. The geometry is 2-D (all Z-coordinate points are 0). I have a simple curve which is not closed. As of now, I am able to import the text file successfully, but when I try to connect the coordinate points using 3D curve option, I get an error while choosing the last few points. This is the error:
"invalid point selection. The curve would become self intersecting"
What could be the reason? Any thoughts?
December 26, 2018 at 7:06 am
Keyur Kanade
Ansys Employeefirst import points.Â
then try to create curve manually in DM. please see if you can create this curve and it is not self intersecting.Â
December 26, 2018 at 9:42 am
ashiadarsh
SubscriberDear kkaade,
This is exactly what I did!!! I cannot simply select few points because of this error. Any other suggestions?
December 26, 2018 at 12:21 pm
raul.raghav
SubscriberCan you attach your text file so we could take a look at it? -
December 28, 2018 at 9:39 am
ashiadarsh
SubscriberDear Rahul,
    Please find the co-ordinates as attached below
1 1 0 52.24540407 0
1 2 1.996661102 52.26684514 0
1 3 10.98163606 52.05646348 0
1 4 19.96661102 51.34393671 0
1 5 29.94991653 49.96330467 0
1 6 42.92821369 47.24168432 0
1 7 55.90651085 43.4723785 0
1 8 68.88480801 38.65538719 0
1 9 77.86978297 36 0
1 10 89.84974958 32.62006653 0
1 11 99.83305509 3.75E+01 0
1 12 106.8213689 41.46222806 0
1 13 117.803005 47.93257399 0
1 14 128.7846411 54.53939849 0
1 15 136.7712855 59.381139 0
1 16 147.7529215 66.03308196 0
1 17 165.7228715 76.76805847 0
1 18 182.6944908 86.59246474 0
1 19 199.6661102 96.00880764 0
1 20 216.6377295 104.9635754 0
1 21 231.6126878 112.4668845 0
1 22 253.5759599 122.8106248 0
1 23 270.5475793 130.2987116 0
1 24 295.5058431 140.5996461 0
1 25 311.4791319 146.8023845 0
1 26 327.4524207 152.7395059 0
1 27 351.4123539 161.203113 0
1 28 379.3656093 170.4680974 0
1 29 399.3322204 176.6925859 0
1 30 426.2871452 184.5357946 0
1 31 446.2537563 189.8790231 0
1 32 469.2153589 195.4630661 0
1 33 493.1752922 200.581734 0
1 34 519.13 205.27 0
1 35 541.09 208.59 0
1 36 563.06 211.46 0
1 37 582.027 213.7782 0
1 38 600 216.1 0
1 39 618.63 219.034 0
1 40 637.1 222.94 0
1 41 655.57 228.51 0
1 42 674.03951 236.58 0
1 43 692.51 248.18 0
1 44 701 255.043 0
January 1, 2019 at 2:49 am
September 11, 2019 at 9:00 am
AdithyaB
SubscriberHi Adarsh,
I had a similar error. The fix was to use same format of numbers as used in your ansys; that is if a comma or dot is the correct input for decimal place.Â
Adithya
January 21, 2020 at 1:24 pm
tayyaba.bano
SubscriberHi
when I import points, i got an error "no of points generated 0". I followed the same steps of importing the .txt file but unfortunately I didn't get points in Design modeler.
Waiting for any kind answer.
Tayyaba
January 21, 2020 at 3:16 pm
Forum ModeratorHave you checked the file format?
January 22, 2020 at 11:25 am
tayyaba.bano
SubscriberIt was mistake in my file, I have done it now.
Thanks
Tayyaba
June 10, 2020 at 12:56 am
AhmedZ
SubscriberHelloÂ
Check the ordering of the points, as like to be from the leading edge through the upper surface then from trailing edge through the lower surface, the idea is not to make the curve self intersected.
you can reorder the points with excel.
- The topic ‘Importing coordinate points in Design Modeler’ is closed to new replies.
5154
1836
1387
1248
