April 5, 2024 at 1:40 pm
williamfraser3
SubscriberIs there a way to import data from a .zbf file to an "Import Source" from a script or can this only be done manually? I can't seem to find a command for it in the scripting documentation.
Thank you!
April 5, 2024 at 4:44 pm
Guilin Sun
Ansys EmployeeIt seems after using zbfload/zbfread, the dataset is a struct, not the regular dataset. thus you may not use script directly to assign the source data in import source.Â
- The topic ‘Importing a .zbf file to an import source from script’ is closed to new replies.
1890
1419
1304
