November 29, 2023 at 3:33 pm
Kevin TIN
SubscriberHello,
For an academic project, we are doing a Fluid-Structure interaction. An issue occur when we import a load from a CFD calculation "A load transfer error has occurred. A load could not be applied to small or defeatured entity. You may select the offending object and/or geometry via RMB on this warning in the Messages window. Please see the Troubleshooting section of the Help System for more information."Â
Do you know where the issue could come from ?
November 29, 2023 at 4:13 pm
Sai Deogekar
Ansys EmployeeHi, did you try checking for the object or geometry where this error is occurring? Maybe you can add some images of that along with a description of what you are trying to simulate.
November 29, 2023 at 4:17 pm
- The topic ‘Imported Load error’ is closed to new replies.
1307
