April 19, 2022 at 9:13 am
charlie_kc
SubscriberI am attempting to import a body temperature load into my static structural analysis, using the body temperature solution generated from my steady-state thermal analysis.
However when I try to import, the "Geometry" section in the "Imported Body Temperature" details remains highlighted yellow, even though I am selecting the bodies (all) from the steady-state analysis. Therefore it is remaining with a question mark next to it, so I can't solve the model.
Can anyone offer insight as to why it's not liking my selected geometries. Are there any constraints as to what you can select for the imported body temperature geometry scope?
April 19, 2022 at 9:57 amdinhan0394
SubscriberCan you share some screenshots?
April 19, 2022 at 4:28 pmcharlie_kc
Subscriber, I have attached screenshots to the original post but I will add them again to this comment as may be an error
April 20, 2022 at 2:02 amViewing 3 reply threads- The topic ‘Imported Body Temperature error – static structural’ is closed to new replies.
5069
1786
1387
1248
