June 14, 2023 at 12:45 pm
Xbuddyin
SubscriberDear Friends,
I need the help to load the result from the Compute Canada to CFD POST (Ansys)., In order to run the ansys file, I create the mesh and prepare my file in the ansys fluent until the initilzation step and click on the save and export the case and save it to the folder. Later on I move the journal file, input.cas.gz file to compute canada. Once I run the file in the ansys on the compute canada, I get the following file in the ansysÂ
a. Case Output: fullcase.cas.gzÂ
b. Data Output: output.dat.htÂ
When I try to upload on the CFD Post , it doesnt work out. Any suggestion, Am I missing any output file format in the jounral file. I can see the result in the fluent component, but what if I want to see the results directly in the CFD post app.Â
Thanks
June 16, 2023 at 12:43 pm
Federico
Ansys EmployeeHello,Â
From Fluent, try the following:
File > Export to CFD-Post... then select the corresponding Surfaces and Quantities you wish to export.Â
June 16, 2023 at 12:50 pm
June 16, 2023 at 1:10 pm
Forum ModeratorIf you've got a case & data file try Load Results. However, in the more recent releases Fluent is the recommended post processing tool.Â
June 16, 2023 at 1:33 pm
Xbuddyin
Subscriber@Rob, I can import the cas.gz in the CFD-POST using the import but it only shows me the geomtery not any results such as velocity or pressure.Â
Whenever I try to upload the data file ( Data Output: output.dat.ht ) on CFD-Post it shows me the error. I am not sure I should load the data.Â
IN FLUENT COMPO: Initall I load the cas.gz file and later dat.ht file and that works there, but I couldnt do the same thing in CFD-Post Not sure If I am missing something out.Â
June 16, 2023 at 2:05 pm
Forum ModeratorCan you reload them into Fluent & resave? I've not seen .dat.ht as a format, and .dat.h5 isn't recognised by CFD Post.Â
- The topic ‘Import Results from the Compute Canada’ is closed to new replies.
6545
1311
