TAGGED: equivalent-von-meises, node, plot-results, results, shear-stress
October 8, 2024 at 4:13 pm
AR
SubscriberHello,
Is it possible to import results from an excel?
I have an excel with the node number, location (x,y,z) and the equivalent von misses stress calculated from the normal and shear stress components of each node.
Can I import it into Ansys to view it on the geometry from which I exported it?
Regards
October 8, 2024 at 5:25 pm
Deepak
Ansys EmployeeHi,
Please refer to this KM:Â How to map Coordinate vs stress data on a problem in ANSYS - Ansys Knowledge
Thanks,
Deepak
October 10, 2024 at 11:13 am
AR
SubscriberHello,
First of all, thanks for the answers.
I have tried to do what is indicated in the link that deepak.deepak has provided.
However, it is not working properly. I have made a model to test it. The first thing I have seen is that instead of importing the 8580 rows that Excel has, it only imports the first 10.
The model on the left (original model) and the one on the right (imported results) should give the same results. However, as you can see, this is not the case. I am attaching an image that shows the normal stress on the Y axis and another one that shows the equivalent von mises stress.
What could be happening?
