August 14, 2024 at 3:55 pm
Amir
SubscriberHi there,
I need to use a special CA distribution over a solid surface, I wrote a code to generate it and successfully works, my question is when applying that profile to the CA in the multiphase setup of VOF, can those profile be considered in deg or should be only in Rad, as my distribution is in deg and complex so I need deg not Radian.
Thanks in advance
August 14, 2024 at 4:11 pm
Forum ModeratorMost of the time Fluent uses radians, but the wall contact angle equations & panels are all degrees. If you set a constant of 90 what happens?Â
August 15, 2024 at 2:41 pm
Forum ModeratorExpressions use a defined unit, are you using one of those or a UDF?
