Import pressure data (coordinates and value) to ansys workbench through excel
    • Saeid Khadem Moshir
      I have encountered a problem that how I can import coordinates and value of pressure into ansys workbench using an excel file.
      Thank you
    • Govindan Nagappan
      You can import the excel file into external data and map it to structural model in Mechanical using "Imported load". The excel file can have  X , Y, Z coordinate and the pressure value.
      Example schematic:
      Double click on the "set up" cell in external data and select the excel file and specify the details. You should see a preview of your data
      Sample preview that shows tempearute import
      You can then use Imported load inside Mechanical and apply the pressure on geometry
      Check help section: Imported Load (Group) (ansys.com)
      External Data (ansys.com)
    • 22sd06014
      Could you please show the format of excel file which is imported. Column names etc. When I am importing I am not able to see the data in the excel file.
      Thanks in advance.
  • The topic ‘Import pressure data (coordinates and value) to ansys workbench through excel’ is closed to new replies.
