Preprocessing
Preprocessing
Import .msh files in Workbench 19.2
    • Saieswar
      Hi!
      Is it possible to import .msh files in workbench?
      if yes,
      1) How to import  . msh file into Ansys workbench?
      2) How to import multiple *. msh file into same session in Ansys workbench?
      Any help will be much appreciated.
      Thanks in advance.
      Importing single/multiple .msh files into Fluent is possible, and very straightforward.  Given Workbench is the project tool why do you want to import mesh files into that?
    • Saieswar
      Thank you!
      But I want to import in "Static Structural".
      Why do you want to import several Fluent mesh files into Mechanical?
    • Abhay_Ranjan
      Hi, i also want know that from where i can insert the .mesh file. As i am learning from the Ansys learning and the first project is to understand the cyclone separator , as in the video it shows that to insert directly the .mesh file but i am not getting it that from where i have to do it ...please help me
      Open Fluent in stand alone mode and go to File - Read and pick Mesh.
    • NeelamMishra
      Hii. I have .msh file generated from Gmsh. I want to import it to Static Structural module in Ansys Workbench. How to do that?
    • NeelamMishra
      How can I use .msh file in Static Structural module
Viewing 7 reply threads
  • The topic ‘Import .msh files in Workbench 19.2’ is closed to new replies.
