May 24, 2024 at 9:41 am
Energizer
SubscriberHello everyone. How can I import mesh to LS-Prepost?
I`m trying open .k file in LS-Prepost which was imported from Workbench LS-dyna. In this case all information from Workbench transfer to LS-prepost but I want only mesh.
Is this possible open .k file only with FEM part or may be I should use other software for mesh and after that open in LS-Prepost?
May 24, 2024 at 1:34 pm
armin.abedini
Ansys EmployeeÂ
Hi Dmytro,
You don’t need another software for meshing. Once you meshed the model in Workbench LS-DYNA, select Write Input File (screenshot below), save the *.k file. Then when you open it in PrePost, there are some additional keyword files that are present as well but you can simply delete them in PrePost using the Keyword Manager (check also the image below).
May 24, 2024 at 1:40 pm
Energizer
SubscriberThanks for your answer, will try.
- The topic ‘Import mesh to LS-dyna’ is closed to new replies.
