August 23, 2021 at 7:01 pm
vitus
SubscriberHello everyone,
I'm trying to define a material for Ansys Structural using my own property values. I already exported values for the 6x6 stiffness matrix (picture below) from another program and now Id like to import them into Ansys.
August 24, 2021 at 10:53 amRahul Kumbhar
The material can be imported in Ansys using xml file. See if there is option to export xml file. From the snapshot it appears you can export cdb file. Try export cdb file and then use 'External Model' system to import the cdb file in Workbench.
August 24, 2021 at 11:41 amvitus
SubscriberThanks for your answer. I think its possible to convert csv to xml... so where can I import xml files?
August 24, 2021 at 2:00 pmAugust 25, 2021 at 12:11 pmvitus
SubscriberHi rkmubhar Ive now created an external model from my cdb file and connected it to my structural analysis in workbench... but i m not sure how to proceed
I need the material data from my cdb file in technical data like it s shown below for structural steel to use it as a material in my structural analysis... where can i find it?
Thanks in advance
September 2, 2021 at 3:33 pmViewing 5 reply threads- The topic ‘import material properties’ is closed to new replies.
5624
1885
1403
1298
