September 25, 2022 at 2:46 am
cskbdia
SubscriberI imported a .iges file from fusion to ansys but when it is generated, 28 surface bodies appeared instead of 1 solid body. I can't use the boolean command because of this. Please give any insight and fix
September 25, 2022 at 7:17 am
Nikhil N
SubscriberHello Cyril,Â
You can use 'Stitch' command from the Repair tab in SpaceClaim or Discovery to create a body out of the surfaces.Â
Nikhil
September 25, 2022 at 3:06 pm
cskbdia
SubscriberI opened the file in Spaceclaim and was able to repair them, But the next problem is a failed boolean and a prompt for "Conversion of body to DesignModeler format failed". I am now looking for workaround this warning. (Sorry if this is an obvious problem/fix I am still new to ansys fluent)
- The topic ‘Import geometry – Surface bodies’ is closed to new replies.
