Import geometry and pre-processing in pyfluent
    • lilly santana
      I wish to import a .stp geometry file into pyfluent, create an O shaped 3D domain and do some named selections. I can only find how to import geometry in meshing stage. Any help will be appreciated.
      Thank you all
    • Nikhil N
      This statement 'I wish to import a .stp geometry file into pyfluent' is in itself not appropriate. It is important to note that PyFluent, or PyAnsys, is not a standalone tool but rather a Python interface for interacting with Ansys products. It primarily facilitates communication with Ansys products in a Pythonic manner. However, for meshing, solving and post-processing, you have the APIs to interface with the Ansys Fluent session. But as a starting point, you would typically need to prepare the CAD separately and have it ready to be imported in Fluent meshing, via PyFluent interfacing.
    • lilly santana
      Thank you
      I have a CAD file but I wish to create named selections and make a domain as would be the case in designmodeler. Can this be done?
    • Nikhil N
      Whatever is possible in Fluent Meshing, can be done through the PyFluent. Hence you may want to review the Fluent Meshing’s capabilities to check what works for you.
    • lilly santana
      so it is not possible to create booleans?
Viewing 4 reply threads
  • The topic ‘Import geometry and pre-processing in pyfluent’ is closed to new replies.
