3D Design
3D Design
import CATIA geometry parameters into ANSYS Workbench through batch commands
    • prapa
      Hej
      I am currently working on a project which requires to import parameters created in CATIA V5 into ANSYS Workbench using batch commands and run the simulation there on. Needed some urgent help with this as I was not able to figure a workaround. Note: This process cannot be performed using a third party app
    • prapa
      Normally, its not reflecting the original parametrization in the design modeler. I have tried using the DS prefix too but it does'nt work.
    • Aniket Chavan
      This needs a third-party app (CADNexus CAPRI CAE Gateway V3.60.0) as mentioned in the help.
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ref_cad/cadCADNexusCAPRI.html
      -Aniket
      How to show full resolution image
      How to use Google to search within Ansys Student Community
    • prapa
      Is there no alternate way to execute this process? Maybe programatically?
    • Keyur Kanade
      You can not import parameters without third party.
      As workaround, please use SpaceClaim. Here you can create your own parameters.
      Please check help document for creating parameters using groups.
      https://www.youtube.com/watch?v=EQFMuUtpRlo
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • Chunyu Zhang
      I am a student of ENSTA Paris, I also need this software.
      I clicked on your link, but I need to enter my Custome number, can you tell me how to find my Custome number?
      Best Regard
      ZHANG Chunyu
Viewing 5 reply threads
  • The topic ‘import CATIA geometry parameters into ANSYS Workbench through batch commands’ is closed to new replies.
