Preprocessing
Preprocessing
Import AutoCAD model to ANSYS
    • bhasura
      I have an AutoCAD drawing which I need to import into the ANSYS Maxwell. I managed to do it by converting AutoCAD block to *.iges format. But once I imported the block to ANSYS Maxwell, I found that the dimensions of the block differs from the original AutoCAD drawing.
      How can I import the AutoCAD drawing correctly with the actual dimensions to ANSYS Maxwell?
      Check the units: that's the most common problem.
  • The topic ‘Import AutoCAD model to ANSYS’ is closed to new replies.
