May 25, 2023 at 12:42 pm
p.ale-martos16
SubscriberHello,
I have a quick question. After selecting my UDF, the name of my UDF ("liquidtogas::libudf") is shown in the box under "user-defined" (see first picture), but when I click apply, the name of my UDF ("liquidtogas::libudf") disappears (see second picture). Is this normal or does this suggest there is a problem with my UDF?
Thank you in advance for your help.
May 25, 2023 at 3:23 pm
Forum ModeratorWhich version are you using? If you "Apply" then switch tabs & return does the label reappear?Â
May 25, 2023 at 3:38 pm
p.ale-martos16
SubscriberI am using 2022 R2. No, if I "Apply" and then switch tabs, the label does not re-appear.
May 25, 2023 at 4:26 pm
Forum ModeratorOdd, it was a problem in an old build but I'd not seen it recently. Whilst I can't say for certain, there's a good chance it's a GUI glitch. See what Solution>Input Summary returns (ribbon menu).Â
- The topic ‘Implementing mass transfer UDF’ is closed to new replies.
