May 14, 2019 at 1:03 pm
Nizar
SubscriberHello everyone,
This is my first post here, but I'm really stumped with this problem. I'll try to explain it the best I could, and you can ask me any question for further explination. So I am trying to model a soil-tunnel-structure model (I'll ask about that later in another discussion). In order to do that, I have to model the soil and its layers. It should be simple right ? I have defined my materials (only elastic properties and damping coefficients), applied a fixed boundary condition (I want to Apply eventually an absorbing boundary condition so I would appreciate if you could point me to some useful article about that), applied a nodel force (tabular force, and divide load by nodes option is turned off), defined a couple of nodes to view their acceleration results (in the direction of the force).Â
So as you can see, here are the nodes. I am using quadratic order elements. The problem I am having is that if I check the B and C nodes' results, they should have the same acceleration value in the Z direction as they are at the same distance from the force, but that is not the case
Node B
Node C
So as you can see there is a big difference in the values. However if I try changing the mesh (it hugely dépends on the sizing), or the order back to linear, I'm not having such problems, however I feel like linear order is not accurate enough. I've done some research, and the only thing I can think of is the way Ansys distributes the forces to the adjacent nodes, or that it got something to do with me placing the nodal force on a mid node. I would like to clear this problem, in order to continue my work without worrying.
Thank you in advance,
Nizar
P.S: I didn't attach the file, because i didn't know which one I should attach, and the associated folder is huge.
May 14, 2019 at 8:45 pm
peteroznewman
SubscriberDon't use Nodal Forces on quadratic elements without taking into account the shape function of the element.
A uniform pressure on a set of quadratic elements does not result in equal forces on each node.
Linear elements have a more predictable nodal force generated from a uniform pressure.
Use the geometry editor to divide the face and then apply a pressure or force to the face. Mechanical will properly distribute that force to the nodes, taking into account the shape function of the elements, be they linear or quadratic.
May 15, 2019 at 8:02 am
Nizar
SubscriberHello Peter,
Thank you very much for your answer, I did create such model and it did work, however I thought it was a lot of hassle to divide a solid into 4 parts just to apply a point load since I can apply it directly on a node. In any case, I will stick with a geometric division.
Nizar
- The topic ‘I’m getting very different results depending on the order and location of the force’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
