February 9, 2026 at 7:20 pm
ah3616
SubscriberHi - I am running an FSI simulation and my ICFD mesh cannot initialize. I have a very fine mesh and mesh controls, MESH_BL, ICFD_CONTROL_GAP and other controls for the FSI mesh. I am running into this error. "
 Implicit dynamics is now active
 ICFD::Mesh -> Start Mesh Generation
 ICFD::Mesh: Initializing.===================================================================================
= Â BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= Â RANK 1 PID 3849779 RUNNING AT g040
= Â KILLED BY SIGNAL: 9 (Killed)
===================================================================================Â
I think it may be due to some of the folds in my parts (which is why I added the ICFD_CONTROL_GAP parameter). but I have not had this issue before until now. Any ideas? thanks
February 18, 2026 at 5:16 pm
igandiko
Ansys EmployeeHello, could you please let me know the version? It seems the solver is terminating abruptly, do you see any traceback in the standard output? You may see some output in the cluster log file or on the terminal (for a local linux run).
February 18, 2026 at 5:22 pm
ah3616
Subscriberthis is my library path: "openmpi-4.1.1_ucx_cuda_11.0.3_support/lib:$LD_LIBRARY_PATH"
my openMPI: "/lsDyna/r1502i/ls-dyna_mpp_d_R15_0_2_x64_centos79_ifort190_sse2_intelmpi-2018"
I can run other files with no issue incluing FSI. this specific FSI model is the only one that fails however it is a new file that has never been run with this mesh or specific parameters combination.Â
Here is my error file:Â
[g040:3849778:0:3849778] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x8)
==== backtrace (tid:3849778) ====
 0 0x0000000000012990 __funlockfile()  :0
 1 0x0000000009f77524 ms_remeshsurf_()  ???:0
 2 0x0000000009f6a9d7 msuite_trisurf_()  ???:0
 3 0x000000000a0f8e33 pfem_trisurf_()  ???:0
 4 0x000000000a100ade pfem_surf_ini_()  ???:0
 5 0x0000000009f48f9c pfem_mk_points_()  ???:0
 6 0x0000000009eacc78 pfem_meshgen2_()  ???:0
 7 0x00000000069d3177 lso_and_d3plot_extended_()  ???:0
 8 0x00000000015a591e wd3plot_()  ???:0
 9 0x00000000015e8839 dynai_()  ???:0
10 0x00000000018c0047 overly_() Â ???:0
11 0x00000000007d5c4b lsinput_() Â ???:0
12 0x00000000007d1335 MAIN__() Â ???:0
13 0x000000000042bf62 main() Â ???:0
14 0x000000000003a7e5 __libc_start_main() Â ???:0
15 0x000000000042be6f _start() Â ???:0
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image        PC         Routine       Line     Source       Â
ls-dyna_mpp_d_R15  000000000EEF1263  Unknown        Unknown  Unknown
libpthread-2.28.s  0000155554B79990  Unknown        Unknown  Unknown
ls-dyna_mpp_d_R15  0000000009F77524  Unknown        Unknown  Unknown
ls-dyna_mpp_d_R15 Â 0000000009F6A9D7 Â msuite_trisurf_ Â Â Â Â Â 6463 Â mk_points.F
ls-dyna_mpp_d_R15 Â 000000000A0F8E33 Â pfem_trisurf_ Â Â Â Â Â Â 1291 Â surfmesh.F
ls-dyna_mpp_d_R15 Â 000000000A100ADE Â pfem_surf_ini_ Â Â Â Â Â 3402 Â surfmesh.F
ls-dyna_mpp_d_R15 Â 0000000009F48F9C Â pfem_mk_points_ Â Â Â Â Â Â 42 Â mk_points.F
ls-dyna_mpp_d_R15 Â 0000000009EACC78 Â pfem_meshgen2_ Â Â Â Â Â 1170 Â geo.F
ls-dyna_mpp_d_R15  00000000069D3177  lso_and_d3plot_ex    15335  lso_and_d3plot_extended.f
ls-dyna_mpp_d_R15 Â 00000000015A591E Â wd3plot_ Â Â Â Â Â Â Â Â 6825 Â wd3plot.f
ls-dyna_mpp_d_R15 Â 00000000015E8839 Â dynai_ Â Â Â Â Â Â Â Â Â 30409 Â dynai.f
ls-dyna_mpp_d_R15 Â 00000000018C0047 Â overly_ Â Â Â Â Â Â Â Â Â 3460 Â overly.f
ls-dyna_mpp_d_R15 Â 00000000007D5C4B Â lsinput_ Â Â Â Â Â Â Â Â 3129 Â lsinput.f
ls-dyna_mpp_d_R15 Â 00000000007D1335 Â MAIN__ Â Â Â Â Â Â Â Â Â 5097 Â lsdyna.f
ls-dyna_mpp_d_R15  000000000042BF62  Unknown        Unknown  Unknown
libc-2.28.so    00001555525457E5  __libc_start_main   Unknown  Unknown
ls-dyna_mpp_d_R15  000000000042BE6F  Unknown        Unknown  Unknown -
February 18, 2026 at 7:00 pm
ah3616
SubscriberI also have run these FSI parameters on a different mesh that has less folds and complexities (overall smoother shape). I have no issues with the mesh initilizing with the smoother mesh. My new mesh has wrinkles which make it more complex - it could be that the version i am using of LSDYNA cannot handle the parameters with the new mesh. I also worry it could be a mesh issue and not a software issue but the more complex the model the more the software issue seems plausible to me.Â
February 19, 2026 at 5:06 pm
igandiko
Ansys EmployeeThank you, it is difficult to debug this issue wihtout the input file. MESH_BL, ICFD_CONTROL_GAP and FSI have been enhanced after R15, could you please try R16? You can also try to identify which feature is causing the issue? Is it MESH_BL? If so, have you tried different MESH_BL options?
February 19, 2026 at 5:22 pm
ah3616
SubscriberI do have a MESH_BL assigned. I use the same as the examples online and add my parts. I will check my version I believe its saved as R15 right now.Â
*MESH_BL
$#   pid   nelth    blth    blfe    blst    bldr   iside
     1     1    0.0    0.0     0     0     0
     2     1    0.0    0.0     0     0     0
     3     1    0.0    0.0     0     0     0
*MESH_BL_SYM
$# Â Â pid1 Â Â Â pid2 Â Â Â pid3 Â Â Â pid4 Â Â Â pid5 Â Â Â pid6 Â Â Â pid7 Â Â Â pid8
     4     0     0     0     0     0     0     0
     5     0     0     0     0     0     0     0
5649
1885
1404
1303
