April 19, 2024 at 8:06 pm
bsanchezgon
SubscriberHello,
A have to continue a transient simulation from a steady state. In this new simulation some components have a time dependency power dissipation. I know a can check de option Transient in thermal block and apply differents function or data.Â
The simulation must last 900 seconds and I have the the cycle of the power which is 2 seconds, For instance:Â
0s 1 W
0.5s 15W
1s 26W
1.5s 5W
2s 0.65W
2.5s 1W
ans so on...
Is there any way to repeat this cycle for every 2 seconds? I would like to add data for n seconds and simulate during X seconds and don`t calculate it every time I do a simulation.
Thanks
April 22, 2024 at 4:26 pm
Iceman
Ansys EmployeeHi, There is no built-in function to support arbitrary cycle. You can use piecewise linear with a dataset for this. The dataset can be imported with .tab format. You can easily create this dataset in Excel and copy it as .tab format. Thanks.-
April 22, 2024 at 5:01 pm
bsanchezgon
SubscriberThat is what I am currently doingÂ
Thanks!
- The topic ‘Icepak Transient simulation’ is closed to new replies.
