Electronics
Electronics
Icepak solver not running
    • Vikram_Atreya
      Hello , Vikram here, I am using a research Mechanical and CFD license and trying to run an Icepak model.
    • Satyajeet Padhi
      Hi Vikram,nYou could try the following to determine if it is an Icepak license denial issue. nIn Icepak, set up everything, mesh the model and put in the required solver settings. Next, in the Solve -> Run Solution panel, under Advanced tab, click Do not start solver. This will generate the case file needed for Fluent to run the problem but not start the iterations.Now, open Fluent, and start Fluent with the same number of processors as you had for Icepak. Read in the case file. We will use a journal file to run the case file. The journal file will be the uns_in file which can be found under the Icepak project folder. nLet us know if you were able to run the icepak project from with Fluent. nSatyajeet n
    • Vikram_Atreya
      Yes the model did run in fluent when i imported it with case file. Thank you!n
  • The topic ‘Icepak solver not running’ is closed to new replies.
