Electronics
Electronics
Icepak in AEDT: Meshing problem
    • jnranhil
      I am getting the following error when I generate the mesh. Can someone please explain the issue?
      Unable to locate or start COM engine on 'Local Machine' : no response from COM engine, timed out (4:26:59 PM Oct 29, 2021)
      Thank you very much for any help.
      Jay
    • Praneeth
      Kindly provide which version of the tool that you are using.
      Also please check if you have required license or not to run the tool by running the license manager on the server.
      All the very best.
    • jnranhil
      Hi Thank you for the reply.
      I am using Ansys electronic desktop student version. (2021 R2).
      Some of the mesh operations of other designs worked properly. So I am not sure what the issue is.
      Thank you for any help!
      Jay
    • jnranhil
      How can I run the license manager on the server?
      Thank you for answering.
      Jay
    • Praneeth
      For student version the license manager case is not applicable.
      Please restart the application and try running it again.
      All the very best.
    • jnranhil
      I already did that. But it is not working. I am getting the same error message. I ran the project on a different laptop, and the project ran without getting any errors. This new laptop has lower features than my laptop but still ran with no errors. So I am pretty sure, the issue is because of something on my laptop. Do you have any clue about that? Do you know what is meant by COM engine?
      Thank you for all the support, really appreciate it.
      Jay
    • Praneeth
      Can you try restarting your system and see if you are able to run the simulation?
      Best regards.
Viewing 6 reply threads
  • The topic ‘Icepak in AEDT: Meshing problem’ is closed to new replies.
