August 22, 2022 at 8:51 am
nurullah.cetin
SubscriberHi,
I need a termal graph which has heat and distance as a parameters. So could you please help me to find it in icepak?
August 25, 2022 at 7:05 am
Satyajeet Padhi
Ansys EmployeeHi,
If you are using Classic Icepak, then go to Post->Variation plot to plot temperature vs. distance.
If you are using AEDT Icepak, then you need to create a polyline, then use Icepak->Results->Create field reports->Rectangular plots. In the panel, select the polyline as geometry and increase the number of points to get a smooth curve. Select temperature as quantity and click on New report to obtain temperature vs. distance.
- The topic ‘Icepak heat graph’ is closed to new replies.
Ansys Innovation Space
1057
1052
1017
947
