TAGGED: AEDT-ICEPAK, ansys-icepak, error, execution-error
September 11, 2024 at 5:34 pm
abdellah
Subscriber Whenever I try to simulate an Icepak model in Ansys, I encounter the following errors.ÂÂ[error] Failed to run solver (6:54:29 PM  Sep 09, 2024)[error] Simulation completed with execution error on server: Local Machine. (6:54:32 PM  Sep 09, 2024)I was wondering if someone could assist me with this issue.
Thanks in advance!ÂÂ -
September 13, 2024 at 2:43 pm
Pdev
Ansys EmployeeHi Abdellah,Â
Thanks for reaching out.Y ou can try to improve the mesh and review the Boundary conditions. Â However, This requires examining the model and unfortunately this is beyond the scope of the Ansys employees as we cannot access attachments on the forum. We encourage other participates in the forum to pitch in if they can help.Â
Thanks!
Pdev -
September 16, 2024 at 4:55 pm
abdellah
SubscriberHi, thank you for your reply. However, this error also occurs when I try to run simulations that work fine on other computers. For example, I was able to run one of the provided examples on another PC, but when I attempt to run it on my computer, I encounter the same error. Therefore, I don’t believe this issue is related to the simulation settings.
Thanks, -
September 24, 2024 at 2:31 pm
Pdev
Ansys EmployeeHi ,
Does the same model work in the other systems? If so, then you can try to reinstall Icepak and run it again.
Best,
Pdev
5819
