Electronics
Electronics
Icepak error
    • kss
      Hdm Fatal error: CART3D FAILED for assembly (mesh region): MeshRegion1
       How to solve this. My model is PCB board and 104 cylindrical capacitors. During meshing this error comes
    • Flaming
      Hi Kshitij, my name is Joey from Icepak Support.
      Regarding this error, it is possible that the mesh associated with meshregion 1 is larger than the target shape or mesh counts are too large so RAM is insufficient.
      Please try the following: 1. use advanced mesh settings instead of slider. 2. reduce the dimensions of the mesh region.
      Thanks,
      Joey Du
  • The topic ‘Icepak error’ is closed to new replies.
