November 6, 2018 at 11:23 pm
tarkanucak
SubscriberHello,
I'm running a simple simulation on ICEPAK. When I try to continue the solution from where it was left off, I get the following error on Fluent screen and solution doesn't continue:
> (read-file-bc "PC1Current2_fullrestart.cas")
Error: Thread_Set_Profile_Var: invalid bc specification
Error Object: #f
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
Note that this occurs when I choose to "Restart" an existing solution. I don't change any bc's or anything. Do you have any recommendations?
November 7, 2018 at 9:58 am
Forum ModeratorCan you check through the settings. I agree that nothing should have changed, but it's a good starting point. We don't have much Icepak experience from the ANSYS side on here, so hopefully the wider community can help.Â
November 7, 2018 at 11:28 am
tarkanucak
SubscriberNothing changes in settings as far as I can see. I isolated the problem to a boundary condition ("resistance" in ICEPAK), trying to figure out why it causes the problem. Thanks for the reply!
December 6, 2018 at 11:47 pm
Satyajeet Padhi
Ansys Employeewhen restarting, make sure you check Full restart and select solutionID.fdat as the restart file. In the solutionID enter a new name so that it doesn't conflict with the old one.Â
Other issues like BCs, you need to check each one individually and try to isolate the problem.Â
- The topic ‘Icepak Can’t Continue the Solution’ is closed to new replies.
3190
1025
962
859
798
