LS Dyna
LS Dyna
Icepak and HFSS Setup in AEDT
    • ha_nguyen3
      I want to study temperature predictions using Icepack coupled with HFSS in AEDT.
      I did the following steps:
      1. Calculate surface loss and volume loss of all objects in HFSS
      2. Copy and paste the geometry from HFSS to Icepak
      3. Set the ambient temp as 24C
      4. Assign Thermal
      5. Assign Thermal
      6. Run "Generate Mesh"
      7. Set up the solver
      In the first attempt, the error was "solve iteration failed. May be solution is diverging got this error: " Failed to run solver" My questions are:
      1. How. do I fix this?
      2. Is there a way to a way to assign initial temperature for each component? My object have multiple components with different initial temperatures that vary from 38-40C.
    • Erik Kostson
      This is an explicit dynamics forum. I would suggest to post this in the appropriate forum (e.g., electronics) in order to get some advice - all the best
      Erik
  • The topic ‘Icepak and HFSS Setup in AEDT’ is closed to new replies.
