November 6, 2023 at 5:56 pm
vkgupta1211
SubscriberCan we localise block splitting in certain regions rather than the full domain?
November 7, 2023 at 5:06 am
Keyur Kanade
Ansys EmployeeBlocking usually used to get full hex mesh. So even if you localize it will be continuous hex mesh. You can use Y or C shape grids. You can search this forum for the same.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
November 7, 2023 at 4:31 pm
vkgupta1211
SubscriberThanks for your response.Â
Yes but on localize, mesh quality gets decreases.Â
November 7, 2023 at 4:47 pm
Keyur Kanade
Ansys EmployeeUse edge biasing.Â
Keyur
November 7, 2023 at 9:19 pm
vkgupta1211
SubscriberI think there is confusion.Â
I am using top-down approach for meshing.Â
When we split the block, full domain gets split. But I want to split the particular blocks not want to propagate it full domain. However the issue is that splitting the particular block reduces the mesh quality.Â
November 8, 2023 at 10:59 am
Keyur Kanade
Ansys EmployeePlease check C type and Y type blocking.Â
Keyur
November 10, 2023 at 6:01 pm
vipul.gupta
SubscriberHelloÂ
I am using ICEM CFD bottom-up approach. After creating 2D block, i want to extrude it for making 3D block. On using, all apppach, interactive , fixed distance and curve and point, it gets failed with error:"extrusion of faces failed"
- The topic ‘ICEM CFD MESHING’ is closed to new replies.
5664
1890
1414
1304
