ICEM CFD 19.1 – Unable to import STEP/IGES geometries
    • terwilliger12
      One of the researchers in an area I support recently had ANSYS ICEM CFD 19.1 installed and he noticed when trying to import a geometry via File >> Import Geometry >> Legacy that "STEP/IGES" is no longer available like it was in the old version he was using (he thinks it was version 13 or 14).  Is it possible to import STEP/IGES files in ICEM CFD 19.1?  If so, what is the process?
      Thanks,
      Ron
    • pjstopfo
      Hi Ron,
      ICEM 19.1 uses a different set of CAD readers from earlier versions, called the 'Workbench Readers'. These are accessed through File > Import Model. This is why the old readers in File > Import Geometry are labelled as 'Legacy'. You should be able to import STEP, IGES and several other formats using the 'Import Model' option.
      Phil
    • terwilliger12
      Thanks pjstopfo, that was the information the researcher needed, much appreciated!
    • Sai Guruprasad Jakkala
      I receive the following error when I try to import the model in STL and IGS format.
      ERROR:
       pIPartMgr->AttachAssembly() failed!
      It also appears when I import the original Solidworks part file.
      Any reason for this error. I tried STP format also.
  • The topic ‘ICEM CFD 19.1 – Unable to import STEP/IGES geometries’ is closed to new replies.
