February 2, 2020 at 5:49 am
krishnaborra95
SubscriberI am trying to modify the piston bowl for an IC engine and I have assembled the piston bowl to the valve and the ports of the default demo file provided by the ansys and I am trying to ruin a simulation. But in the Decomposition step the file is not decomposed and I am not able to change the compression ratio of the piston. Could anyone please tell me how can I assemble my modified piston bowl to the valve and port geometry and run the simulation.Â
February 3, 2020 at 10:24 am
Forum ModeratorHow does it compare to the tutorials?
February 3, 2020 at 12:35 pm
krishnaborra95
Subscriber -
February 3, 2020 at 3:32 pm
Forum ModeratorSo you'll need to work through what's different. Staff are not permitted to open/download attachments so you'll have to compare & work it out.Â
- The topic ‘IC engine piston bowl modification ?’ is closed to new replies.
1565
1386
1242
