April 3, 2024 at 7:12 pm
Sebastià González
SubscriberHello! I am using the latest version of Ansys Student, which includes Ansys forte. Seemingly, the IC engine Analysis system doesn't appear, although Forte does appear in the component systems. How can I fix this problem and use IC engine?
April 4, 2024 at 2:01 pm
SVV
Ansys EmployeeHi,
The IC Engine (Fluent) system is being deprecated and is removed in the latest releases. You can consider using Forte in Component Systems for conducting simulations of internal combustion engines in Workbench.
- The topic ‘IC engine not found in Workbench’ is closed to new replies.
1307
