October 15, 2020 at 10:50 am
veera
Subscriberdear sir
i am simulating the ic engine (diesel -air mixture) with species transport and finite rate
what is the Exponent term while setuping the reaction and protectant ..if i keep everything one i am getting result lesser peak pressure and if i very the exponent term from 1 to 0.5 or different different values that pressure also changes with temperature what is the appropriate value we need to set for corresponding reactant coefficients?
#but my coefficients are correct
October 16, 2020 at 2:07 pmRob
Forum ModeratorIf you click on the Help button the panel documentation will appear, that usually has links to all of the options available. nOctober 17, 2020 at 12:37 pmveera
Subscriberi am using student version, so help wont work, any other waysnViewing 2 reply threads- The topic ‘ic engine analysis’ is closed to new replies.
5149
1831
1387
1248
