TAGGED: hexahedral-mesh, mechanical, mesh, mesh-generation, structural-mechanics
August 11, 2020 at 10:05 amrfkgSubscriber
Hi All,
I have tried every mesh method and cannot get an even hexahedral mesh. In the i have already simplified my assembly so much and it still will not mesh properly.
With the Multizone i shouldn't have to split the bodies myself to create sweepable geometry. However even if i do split them i will still get either errors or an overcomplicated tet mesh.
Any help would be appreciated.
See pictures attached
August 11, 2020 at 10:49 ampeteroznewmanSubscriberDo more slicing. If you are in SpaceClaim, make a Component for each part. Then make cylindrical surfaces and planes at every face. Cut all parts with all surfaces and planes. You will end up with only 4-face rings and 3-face cylinders. At that point, go into Workbench and click the Share button so that all the bodies will have congruent meshes. Since every body is sweepable, you will get a hex mesh.nAugust 11, 2020 at 11:05 amAshish KhemkaForum ModeratornnCan you please try changing the Src/Trg Selection to Manual and then specifying the source and target faces? Also, please check you do not have any sliver faces.nnRegards,nAshish KhemkanAugust 11, 2020 at 11:43 amrfkgSubscriberHinthanks for the reply. I have sliver faces because i imprinted the solid on each other in the hopes of forcing a better mesh. Since this wasn't working i used virtual topology to join tangent faces and removed all slivers. I will try the manual src/trg thanks.nthanks for the reply. What do you mean make a component for each part? I am not familiar with the difference between the two. I spaceclaim i split each sweepable body to make it simple for multizone so my tree looks like thisnwhen shown in mechanical it looks like this, which is a bit odd sine as you can see the two bodies that constitute the window havent been grouped.nbut as you can see i only have 4 face ring and 3 face cylinders already. no slivers. cannot wrap my head around how such a simple geometry is not generating a full hex mesh.nI cannot find how to share in workbench. do you mean create a shared topology in spaceclaim?nRegards,nRafiknAugust 11, 2020 at 11:55 ampeteroznewmanSubscriberI see you already have three components in SpaceClaim: Window, Spacer and Frame. That is three parts, but I see six parts in the section below.nYes, shared topology in SpaceClaim is done by using the Share button in the Workbench tab. Below I show three orange lines that represent cylindrical surfaces that would cut those bodies into simple sweepable bodies with congruent meshes where they touch.nnViewing 4 reply threads- The topic ‘I have a very simple geometry but ansys won’t make an even hexahedral mesh’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Element type definition – Ansys Workbench
- Varying ply angle in ACP
- CONVERTING STL FILE IN TO SOLID
- The meshing algorithm cannot find matching topology
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- [ANSYS Meshing] how to activate curvature for a sizing in a script?
- How to create a mapped mesh in a chain link model with stud.
- Discovery 2024 R2 Crashing
Top Contributors-
1602
602
599
591
366
