November 15, 2020 at 7:20 am
soham
SubscriberNovember 15, 2020 at 10:30 pmpeteroznewman
SubscriberAdd a Modal analysis to your Model cell. Drag and drop the Fixed Support on the Modal analysis. You will find that the lines are not all connected.n
Go back to SpaceClaim and use Shared Topology to connect the beams together.nAnother way to do this is to Insert a Node Merge Group and merge the coincident nodes to connect the beam.n
n
November 16, 2020 at 4:58 amsoham
Subscriberthank you so much sir . Have two more queries n1. I have different tube cross sections which for time being I have modelled as single profiles so is it possible to apply different cross section to the tubing and still connect them ?n2. What are the best resources to learn Ansys commands and their functionalities you'll refer sir ? nNovember 17, 2020 at 1:00 ampeteroznewman
SubscribernYes, each line can have its own profile using either method.nThere are many free courses under the Courses section at the top of this page.nViewing 3 reply threads- The topic ‘I had this solver pivot warning tried different ways but cannot resolve please help .’ is closed to new replies.
5664
1890
1419
1304
