i get lisence error saying could not connect to lisence server 62962@.1.2.7.0.0.1. System Error: )””
September 29, 2021 at 2:37 pm
shreeniwas_patil
SubscriberOctober 1, 2021 at 1:46 pmGeorge Karnos
Ansys EmployeeI will ask you to please stop opening new threads concerning the same issue.
Please concentrate on the following link:
/forum/discussion/comment/132076#Comment_132076
October 1, 2021 at 2:47 pmshreepatil14
SubscriberI actually followed the exact same procedure again also added firewall exceptions but only 4 toolbars are there which cannot be expanded in tree modular and spaceclaim doesnot function properly .
It only shows lisence error
The previous thread / link doesnot solve the query.
It's almost been a month since I asked this doubt I hope that my ansys software works properly as I am in college project called TIFAN SAE INDIA and I am in dire need of this software I am literally writting in notebooks to learn ansys drawing program windows and all
See .......
Please solve this
October 1, 2021 at 4:11 pmGeorge Karnos
Ansys EmployeeCan you try setting the following Windows system environment variable:
Variable: ANSYSCL_BIND_TO_LOOPBACK
Variable Value: 1
October 2, 2021 at 5:17 amOctober 2, 2021 at 11:46 amGeorge Karnos
Ansys EmployeeTry to run Workbench
October 2, 2021 at 2:48 pmOctober 5, 2021 at 6:47 amshreepatil14
SubscriberShall I try to reinstall ansys and again ask query if problem arises
October 5, 2021 at 12:18 pmshreepatil14
SubscriberHello ƒæï
Can you please answer my question
October 5, 2021 at 12:22 pmGeorge Karnos
Ansys EmployeeUninstall.
rename the c:\Program Files\Ansys Inc directory to ANSYS Inc_old
Reinstall by right-click on setup.exe and choosing run as administrator
try to run.
Post the results.
October 5, 2021 at 3:27 pmOctober 5, 2021 at 3:29 pmGeorge Karnos
Ansys EmployeeWhat is the size of the downloaded installation file?
Are there any errors in the install.log or install.err file under c:\program files\amsys Inc\Ansys Student
October 5, 2021 at 3:57 pmshreepatil14
SubscriberFile size is.
Downloaded file size. 77,17,726kb
Extract downloaded file size.
Size. 7.42GB. 7,97,02,63,130 bytes
Size on disk. 7.42 GB. 7,97,06,19,392 bytes
Contains 201 files 156 folders
# Setup 15,177kb
Install.err is not present and install.log seems to have no problem
October 5, 2021 at 7:26 pmCD18mn
SubscriberI am having the exact same problem only with the 2020 R2 version of ANSYS, I have also tried all previous solutions and those above which do not seem to help
October 6, 2021 at 3:26 amshreepatil14
SubscriberHope our queries get quickly resolved
October 6, 2021 at 12:45 pmshreepatil14
SubscriberPlease answer my query as deadline for our project is closing in
October 6, 2021 at 1:01 pmANSYS_MMadore
Forum ModeratorCan you please open a command prompt and run the command "set" without the quotes and send the FULL output?
October 6, 2021 at 2:45 pmGeorge Karnos
Ansys EmployeeAre you using any type of VPN software?
Also, can you post any errors listed in any of the .out or .log files under: %TEMP%\.ansys
These are debug files and log files for licensing.
October 6, 2021 at 3:34 pmOctober 6, 2021 at 3:37 pmANSYS_MMadore
Forum ModeratorPlease try deleting the variables ANSYSLIC_DIR and ANSYSLMD_LICENSE_FILE.
For guidance on Environment Variables please refer to this link. You need to delete the variables I've named above.
https://www.onmsft.com/how-to/how-to-set-an-environment-variable-in-windows-10
October 6, 2021 at 4:05 pmOctober 6, 2021 at 4:24 pmGeorge Karnos
Ansys EmployeeOctober 7, 2021 at 4:50 amOctober 7, 2021 at 5:07 amOctober 7, 2021 at 5:08 amshreepatil14
SubscriberPlease answer my query if the problem arises again
October 7, 2021 at 6:00 amOctober 7, 2021 at 8:01 amVaibhav Dixit
Ansys EmployeeGo to %temp% directory , it make open "C:\Users\Lenovo\Appdata\Local\Temp"
Do you see folder '.ansys' there?
Can you create a new file there in temp directory?
October 7, 2021 at 8:21 amOctober 7, 2021 at 9:24 amVaibhav Dixit
Ansys EmployeeKindly share file ansyscl.Desktop-HR3NS3T to 'india-systems-support@ansys.com'.
Can you run these commands in command prompt and share their output:
ping localhost
ping localhost -4
ping %computername%
To take screenshot, you can use 'PrtScr' (Print Screen) button on your keyboard. After capture, you can paste the screenshot in Microsoft Paint.
Thanks
Vaibhav
October 7, 2021 at 11:37 amshreepatil14
Subscriberi have submitted to the given mail-id
October 7, 2021 at 12:00 pmOctober 7, 2021 at 12:16 pmOctober 7, 2021 at 12:41 pmVaibhav Dixit
Ansys EmployeeReceived
October 7, 2021 at 12:51 pmshreepatil14
SubscriberNext step?
October 7, 2021 at 1:00 pmVaibhav Dixit
Ansys EmployeeWhat is the output of command: ping %computername% -4
October 7, 2021 at 1:04 pmVaibhav Dixit
Ansys EmployeeAdd these Environment Variables and try again. Yesterday, Geo has explained how to check and add an Environment variable.
ANSYSCL_TIMEOUT_CONNECT = 60
ANSYSCL_TIMEOUT_RESPONSE = 300
October 7, 2021 at 1:05 pmOctober 7, 2021 at 1:27 pmVaibhav Dixit
Ansys EmployeeNow Try this one
October 7, 2021 at 1:37 pmGeorge Karnos
Ansys EmployeeAlso:
Can you please open a dos command prompt window and run:
WMIC /OUTPUT:c:\temp\_WMICsoftware.log product get name,version /format:list
This should create c:\temp\_WMICsoftware.log
Please paste the contents of that file. (open in notepad and copy and paste to here))
October 7, 2021 at 2:26 pmOctober 7, 2021 at 2:28 pmGeorge Karnos
Ansys EmployeeMake sure a directory c:\temp exists. If it does not, create that directory.
Then try the command again
October 7, 2021 at 2:37 pmGeorge Karnos
Ansys EmployeeI see you left out a space...Between _WMICsoftware.log and product and get and name...
Try copying the above command and pasting it in the command prompt or the run field.
October 7, 2021 at 3:12 pmshreepatil14
SubscriberName=VBA (3821b)
Version=6.01.00.1234
Name=DS License Server
Version=6.222.02460
Name=Microsoft VC++ redistributables repacked.
Version=12.0.0.0
Name=Quick Heal Total Security
Version=19.00
Name=Intel(R) Management Engine Components
Version=1.0.0.0
Name=Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.21005
Version=12.0.21005
Name=Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.21005
Version=12.0.21005
Name=
Version=
Version=12.0.0.0
Name=Intel(R) Chipset Device Software
Version=10.1.17695.8086
Name=Intel(R) Management Engine Driver
Version=1.0.0.0
Name=Microsoft Visual C++ 2017 x64 Minimum Runtime - 14.13.26020
Version=14.13.26020
Name=Java 8 Update 261 (64-bit)
Version=8.0.2610.12
Name=Intel(R) Trusted Connect Service Client x86
Version=1.50.638.1
Name=Intel(R) Trusted Connect Service Client x64
Version=1.50.638.1
Name=Microsoft Update Health Tools
Version=2.83.0.0
Name=Visual Basic for Applications (R) Core - English
Version=6.5.10.32
Name=Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.21005
Version=12.0.21005
Name=Dolby Audio X2 Windows API SDK
Version=0.8.8.88
Name=Adobe Refresh Manager
Version=1.8.0
Name=Adobe Acrobat Reader DC
Version=21.007.20095
Version=1.0.0.0
Name=Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.21005
Version=12.0.21005
Name=Dassault Systemes Software VC9 Prerequisites x86-x64
Version=9.1.2
Name=Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030
Version=11.0.61030
Name=Microsoft Visual C++ 2017 x86 Additional Runtime - 14.13.26020
Version=14.13.26020
Name=Dassault Systemes Software Prerequisites x86-x64
Version=8.1.3
Name=Microsoft Visual C++ 2017 x64 Additional Runtime - 14.13.26020
Version=14.13.26020
Name=
Version=
Name=Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030
Version=11.0.61030
Name=Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030
Version=11.0.61030
Name=Microsoft Visual C++ 2017 x86 Minimum Runtime - 14.13.26020
Version=14.13.26020
Version=6.5.10.53
Name=Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030
Version=11.0.61030
Name=Dolby Audio X2 Windows APP
Version=0.8.6.75
Name=Java Auto Updater
Version=2.8.261.12
Name=
Version=
Name=Java(TM) SE Development Kit 13.0.1 (64-bit)
Version=13.0.1.0
October 7, 2021 at 3:29 pmGeorge Karnos
Ansys EmployeeThere is a software installed named : Quick Heal Total Security
Have you tried turning off the firewall in Quick Heal Total Security?
October 7, 2021 at 4:04 pmOctober 7, 2021 at 4:26 pmOctober 7, 2021 at 4:50 pmGeorge Karnos
Ansys EmployeeExcellent!
I will go ahead and close this thread.
Viewing 46 reply threads- The topic ‘i get lisence error saying could not connect to lisence server 62962@.1.2.7.0.0.1. System Error: )””’ is closed to new replies.
5669
1890
1419
1304
