June 11, 2018 at 5:13 pm
June 11, 2018 at 6:16 pm
Aniket Chavan
Forum ModeratorHi Luiz,
The beam tool that you are trying to access is only applicable for line bodies. It seems that you are using a solid body to model the beam. In that case, it will not be applicable.
Aniket
June 11, 2018 at 6:23 pm
luizhenriquebarbosa16
SubscriberThank you very much.
May 31, 2019 at 4:15 pm
Devasish
SubscriberDoes this mean that if we are using solid body to model a beam we can;t have the BMD and SFD?? or is there any other way to obtain BMD AND SFD?? I am trying to model an I-section girder.
- The topic ‘I can’t use beam tools in the Mechanical (Ansys Workbench 19.0, Student Version).’ is closed to new replies.
1890
1419
