October 28, 2020 at 7:29 am
moranlouie
SubscriberHere are the radiation settings:
October 28, 2020 at 11:09 amRob
Forum ModeratorDoesn't run at all or diverges? What messages do you see in the TUI window?nOctober 28, 2020 at 1:16 pmmoranlouie
SubscriberI am getting the same warning you might have seen in my previous questions: nError at host: Monte Carlo radiation model set up is not correct.nIs it really just the use of a semi-transparent wall that is creating this error? If so, how do I simulate photon vectors going thru glass or transparent walls?nThanks!nOctober 28, 2020 at 1:33 pmRob
Forum ModeratorUse a solid: it just says it doesn't like thin walls. nViewing 3 reply threads- The topic ‘I can’t get the Monte Carlo Ray Tracing Model to run on my Fluent simulation’ is closed to new replies.
5014
1682
1387
1248
