I cannot use UDFs that need hooking in RockyDEM 2-way coupling
    • zhou333708124
      I set 2 UDFs in my case
      One is "DEFINE_EXECUTE_ON_LOADING" type, this UDF can be auto run and it execute correctly.
      The other is "DEFINE_EXECUTE_AT_END" type, this UDF need to be hooked and it cannot execute in calculation process.
      I check the "start_coupled.jou" and "fluent.log" written by RockyDEM, and I found Rocky set its own UDF by "/define/user-defined/function-hooks/execute-at-end "exchange_rocky_fluent_coupling_data::rocky_fluent_coupling" "inject_remove_particles::rocky_fluent_coupling" """
      This command hooks those two UDFs to execute-at-end, my UDF has been replaced or just not get hooked, so I cannot use UDFs that need hooking in coupling. This command is execute automaticly by Rocky.
      As the Rocky coupling start, there are nothing I can do to pause the process or exchange the files, so if there are anyway to hook my UDFs automaticly?
    • Jackson Gomes
      Hi Zhou,
      Rocky automatically sets its own UDFs in execute-at-end, replacing yours. To work around this:
      1. Use a different hook, like DEFINE_ADJUST.
      2. Modify start_coupled.jou before execution to add your UDF.
      3. Append your UDF to the same hook manually if possible.
      • zhou333708124
        Thanks Jackson.
        DEFINE_ADJUST cannot be hooked normally. As you can see, execute-at-end, initialization and adjust are all replaced.
        But some of DEFINE_PROFILE UDFs can be executed.
        To modify start_coupled.jou or hook my UDF manually have the same problem that I can’t pause the process, the calculation is automaticlly execute by Rocky, and if I change the .jou file the process will be shut down.
        If there are any option for user to pause the process and adjust the setting manually?
        Best wish for you
    • Jackson Gomes
      Dear Zhou,
      Which Rocky version are you using? Also, can you check your .cas file in a text editor like Notepad++ and look for udf/execute-at-end-fcns, udf/init-fcns, or udf/adjust-fcns?
       If Rocky is replacing everything, have you tried running Fluent in interactive mode before starting the coupling?
