December 6, 2020 at 4:08 pm
munkhunur
SubscriberHello dear @tsiriaks
After upgrading my ansys 19.2 to 19.3 my project files can not open with this below error. Shortcut of files also does not recognize as ansys file pattern.
Please help me how to fix this error.
December 7, 2020 at 12:15 pmRob
Forum ModeratorWhy did you update to R19.3 and not 2020R2? Can you create a new project and go through a very simple geometry, mesh & solver? This is to test the new install. nDecember 8, 2020 at 12:34 pmmunkhunur
SubscriberDear Rob, Thanks a lot. nI was afraid that If I install 2020R2 with failure I can not go back with my old files to 19R version. nI though that files can be shared each other on both R19.2 and R19.3. Unfortunately, I came back to R19.2. nThanks againnUnur nDecember 8, 2020 at 4:10 pmRob
Forum ModeratorFiles from earlier versions tend to open in later builds. I'm not sure why you're having problems with R19.3 with files from R19.2 as nothing much changed (that effects loading). nViewing 3 reply threads- The topic ‘I can not open files in ansys 19 R3’ is closed to new replies.
