October 20, 2019 at 7:15 pm
fkezada5
Subscriberhi guys! nice to meet you, my name is felipe quezada, from Chile.
i really need your help. i made some models of " I BEAM - CFT (concrete filled tube) column connections" in ansys worbench V 15.0.
my problem is related to how to model the behavior of concrete inside de column. i have read about the element solid65, which is one of the most appropiate element for this case. i have copied some codes in the command option, but when i try to run the program, it doesn't work.
i tried to model a simple concrete cube with the code of solid65, but nothing happens.
fkezada5
Subscriberi tried to input the following code
CONCRETE COMMANDS:
ET,MATID,SOLID65
R,MATID,0,0,0,0,0,0
RMORE,0,0,0,0,0
MP,EX,MATID,29250
MP,PRXY,MATID,0.2
MPTEMP,MATID,0
TB,CONCR,MATID,1,9
TBTEMP,22
TBDATA,
1,0.3,0.8,1.5,25
TB,MISO,MATID,1,35,0
TBTEMP,22
TBPT,,0.0001,2.925
TBPT,,0.0002,5.7
TBPT,,0.0003,8.325
TBPT,,0.0004,10.8
TBPT,,0.0005,13.125
TBPT,,0.0006,15.3
TBPT,,0.0007,17.325
TBPT,,0.0008,19.2
TBPT,,0.0009,20.925
TBPT,,0.001,22.5
TBPT,,0.0011,23.925
TBPT,,0.0012,25.2
TBPT,,0.0013,26.325
TBPT,,0.0014,27.3
TBPT,,0.0015,28.125
TBPT,,0.0016,28.8
TBPT,,0.0017,29.325
TBPT,,0.0018,29.7
TBPT,,0.0019,29.925
TBPT,,0.002,30
TBPT,,0.0021,30
TBPT,,0.0022,30
TBPT,,0.0023,30
TBPT,,0.0024,30
TBPT,,0.0025,30
TBPT,,0.0026,30
TBPT,,0.0027,30
TBPT,,0.0028,30
TBPT,,0.0029,30
TBPT,,0.003,30
TBPT,,0.0031,30
TBPT,,0.0032,30
TBPT,,0.0033,30
TBPT,,0.0034,30
TBPT,,0.0035,30
please, i really need some helps, these models are to my degree.
thanks! and i´m sorry for my english, it is not the best ha ha ha
August 11, 2023 at 8:34 pm
ramon mata
Subscribercould you solve your problem? what solution did you take? any recommendation is welcome
- The topic ‘I beam to CFT column , concrete´s behavior – solid65’ is closed to new replies.
3597
1208
1092
1068
952
