April 26, 2022 at 10:21 am
Amith_Anoop_Kumar
SubscriberApril 26, 2022 at 1:57 pmVigneswaran Sridharan
Ansys EmployeeHey Check out this Forum thread on generating Semi elliptical crack.
Semi-Elliptical Crack Definition for SMART Crack Growth ÔÇö Ansys Learning Forum
https://youtu.be/8fy0hmTITEQ - This video helps you get started with SMART Crack Growth tool.
3.2. SMART Method for Crack-Growth Simulation (ansys.com) also has relevant info on the tool
Vigneswaran
Ansys Help
Rules & Guidelines ÔÇö Ansys Learning Forum
April 26, 2022 at 3:07 pmAmith_Anoop_Kumar
SubscriberRespected Sir My issue is with only generating the semi elliptical crack . I want to generate semi elliptical crack in stress concentrated regions and in mid region but only at certain places i am able to make the crack generated
April 26, 2022 at 4:39 pmAshish Khemka
Please see if the following helps (refer to all the 3 parts):
Pressure Vessel Simulation with Crack Intialization - ANSYS Mechanical Part 3/3 - YouTube
Regards Ashish Khemka
April 26, 2022 at 9:35 pmAmith_Anoop_Kumar
SubscriberThank you for the link but my here the video i had followed but couldnt reach the end results. My main aim is to generate cracks in the welded regions which i am not able to do. That is the regions shown below.
Also i always get a warning
A fracture result is specified by time instead of by set. If the time lies between two result sets, no interpolation is performed.Instead, there are two possibilities: (1) if there are no mesh changes, the lower set applies; (2) if there are mesh changes, the closest set applies.
2.The fracture parameters computed during solution may be incorrect. Check the Solver Output on the Solution Information object for possible causes.
How to rectify these too
Viewing 4 reply threads- The topic ‘I am not able to generate a semi elliptical crack’ is closed to new replies.
5674
1890
1419
