I am getting the error ‘Solver pivot warnings or errors have been encountered during the solution..’
March 25, 2020 at 4:38 pm
Abidos98
Subscriber I have been trying to solve this section of a PV panel as shown in the image below, but have been receiving the error, 'Solver pivot warnings or errors have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully.'Â
March 25, 2020 at 5:59 pm
peteroznewman
SubscriberPlease make the simplest version of a Steady State Thermal model you can imagine out of a sheet body. Can you simulate a textbook example where you know the answer? Then try a model with one sheet body divided into two faces. Show that you can solve simple models first.
- The topic ‘I am getting the error ‘Solver pivot warnings or errors have been encountered during the solution..’’ is closed to new replies.
Ansys Innovation Space
1394
1188
1100
1015
