September 7, 2025 at 10:41 am
adib.aktab999
SubscriberIn my simulation particle injected from the surface of mouth, it should have spreaded to the room but the particles are dropping soon. I have used 2 inlets and one one outlet. The inlets have 3m/s velocity and the outlet is the pressure outlet. I have used water liqid as injection material. i Have ran the simulation for 1 sec. the room volume is 738m^3
September 8, 2025 at 6:23 am
SRP
Ansys EmployeeHi,
If gravity is enabled, heavy water droplets will settle fast. For testing, try to turn gravity off to see if they otherwise spread
September 8, 2025 at 2:40 pm
adib.aktab999
SubscriberYeah I have tried, still the particles are falling. How can I resolve it?Â
should I decrease the particle size or  increase the inlet, outlet velocities? -
September 9, 2025 at 5:10 am
adib.aktab999
SubscriberYeah I have tried without gravity, it is same. So I increased the velocity and decrease the diameter. And also I was doing the simulation for 1 sec, that could be a reason.
I am running for 1 min now. Lettsee
6765
1330
1127
