March 31, 2021 at 6:39 am
erwin
SubscriberHi! I'd like to ask if there is a way to re-import a geometry and have it in the same tab as the first one? I accidentally deleted the turbine geometry below from the first tab named "FFF" which I will be using later on in another simulation. When I re-import the geometry it opens in a new tab, is there a way to bring it to the first tab?
Thanks in advance!
March 31, 2021 at 8:20 amKeyur Kanade
Ansys EmployeeGo to first tab and use undo. nIf that does not help, select geometry in second tab. Copy and paste it in first tab. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 31, 2021 at 1:53 pmerwin
SubscriberThank you Sir Keyur!nViewing 2 reply threads- The topic ‘I accidentally deleted an imported geometry, upon importing again it opens in a new tab’ is closed to new replies.
3150
1013
946
858
797
