TAGGED: hyperelasticity, hyperplastic, material-properties
May 31, 2023 at 8:28 am
Jia-Wei Liao
SubscriberWhen I was doing nonlinear simulation of large deformation of breast compression, I saw that some papers used hyperelastic Mooney–Rivlin model, and some papers used hyperelastic neo-hookean model in the selection of breast material properties.ÂI used Mooney–Rivlin at the beginning, and the result was element highly distorted error. Later, I switched to neo-hookean and the other conditions were the same, and the calculation converged successfully.ÂI would like to ask what is the main difference between Mooney–Rivlin and neo-hookean? Why can the highly distorted element be solved after changing the material properties? The calculation results using neo-hookean will be more inaccurate than Mooney–Rivlin ?
Thanks for your help!!! -
June 1, 2023 at 7:57 pm
John Doyle
Ansys EmployeeBoth models are based on a strain energy density function. Â NeoHookean is the simplest (mathematically) of all the hyperelastic options, but it also is limited to relatively small strain (<30%) and typically only curve fits well for mildly nonlinear stress strain curves without inflection points.Â
I would refer you to Section 4.6 of the MAPDL Material Reference Guide available online for a more rigorous explanation of all the hyperelasticity material options. Â Â
If NeoHooekan result passes all your validation requirements, then you should be fine to use it.
- The topic ‘Hyperelastic : Mooney–Rivlin vs. neo-hookean’ is closed to new replies.
