August 29, 2024 at 8:28 pm
Heidi.Feigenbaum
SubscriberI am wondering if I can input a strain energy density function for a hyperelastic material. I see that I can put in experimental data using a response function. But in this case, I want to use the strain energy density function that other researchers found, not stress-strain data. I know that I could define a USERMAT, but since it is hyperelastic (no plastic deformation), I am wondering if there is a simple way to just enter the strain energy density as a function. I appreciate any guidance on this!
August 30, 2024 at 11:45 am
Aurojyoti Prusty
Ansys EmployeeHi Heidi,
Yes, you can define a hyperelastic material using only the strain energy density function. In engineering data, you drag and drop the Hyperelastic model of interest and then input the material parameter related to that strain energy function (If you know it already). If you do not know, then you need to curve fit the experimental data. For example, If I try to input a simple Neo hookean energy density function, I need to define Initial shear mod. and Incompressibility parameter D1. Same procedure for other strain energy density function.
Hope this Helps.
Thanks,
Aurojyoti
