TAGGED: 2D, axisymmetric, contact, hyperelastic, membrane, mooney-rivlin, rubber
October 18, 2023 at 9:36 am
przemyslaw.oborowski
SubscriberTAGS: #membrane, #fabric, #contact, #nonlinear, #hyperelastic, #rubber, #Mooney, #Rivlin, #axisymmetric, #2D
Hello!
I'm trying to do the 2D axisymmetric simulation of the membrane shown in the picture below:
The simulation is divided in 2 steps
1. 0-0.5s -> initial pressing bu the contacts (ramped effect)
2. 0.5s-1.5s -> Yellow element displacement for 0.7mm down, which squezes the membrane further.
Here is a mesh used in the last trial (TRI6, QUAD 4), but I've already tried multiple variants of meshing:
The problem occurs around 1.33s/1.5s and it seems, that it is connected to the nodes sticking to the rigid surface.
More movies available under the link:https://drive.google.com/drive/folders/1UfyaO8rZtcG1z30jZVi5YS1pxFateEkk
The contact is defined as below (place, where the the possible problem occured, marked with arrow):Simulation setup:
Max. Newon-Rapson residual was located here:Error (similar for all elements):
Rubber properties:
Could You please help me in this issue? :)
Thank You in advance for support! -
October 20, 2023 at 1:40 pm
John Doyle
Ansys EmployeeBelow are a few tips to try:Â
- Drop midside nodes. The linear shape functions can sometimes offer better stability. Â
- Consider a coarser mesh. Not too coarse, but slighly larger elements might be less suceptible to element distortion errors, since their integration points are not so close to the boundary.
- Switch back to Aug Lagrange and reduce the contact stiffness.
- Use many more substeps.
- If the above tips do not help, consider adding Nonlinear Adaptive Meshing.
- The topic ‘Hyperelastic material simulation issue’ is closed to new replies.
2979
970
857
755
599
