September 13, 2023 at 3:26 am
nhanani4
SubscriberHi,
I do the hydrodynamic pressure in three modular floating structures in ansys aqwa. I want to link the hydrodynamic pressure from ansys aqwa to ansys static.
May I ask if in ansys static can only apply one hydrodynamic pressure for one module floating structure?
It cannot be added another hydrodynamic pressure for another module?
 Because the hydrodynamic pressure detects only one module and can not add another hydrodynamic pressure for another two modules.
thankyou
September 18, 2023 at 2:04 pm
Ashish Khemka
Forum ModeratorHi,
Can you try exporting the pressure data and applying the same as Tabular data in Static analysis?
Ashish Kumar
October 10, 2023 at 7:06 am
Mike Pettit
Ansys EmployeeHello,
In a Static Structural analysis the Hydrodynamic Pressure object can only map pressures from one structure in the hydrodynamic model.
If the hydrodynamic model contains many structures, then Direct mapping must be used. You can select faces from multiple structures in the structural model, but the mapped pressure values can only be derived from one structure in the hydrodynamic model.
If you have separate modules in the hydrodynamic model, and you are mapping on to separate modules in the structural model, then I suggest you carry out a separate Static Structural analysis for each module.
I hope this helps.
Mike
- The topic ‘hydrodynamic pressure’ is closed to new replies.
5879
1306
