September 23, 2024 at 7:44 pm
September 24, 2024 at 4:26 pm
Guilin Sun
Ansys EmployeeCould you please elaborate more regarding to the results you want? what source you are using? it seems like a plane wave but the structure seems not periodic. This can only be an approximation. Usually plan wave should match with periodic boundary conditions. Please consider it carefully.
We have examples for your reference:
https://optics.ansys.com/hc/en-us/articles/360042089353-Resonant-bio-sensor-gratingÂ
https://optics.ansys.com/hc/en-us/articles/360042833173-Thermally-tuned-waveguide-sensor
https://optics.ansys.com/hc/en-us/articles/11036662048787-Fiber-Bragg-Grating-Temperature-Sensor
You can certainly simulate the sensitivity.
September 24, 2024 at 5:22 pm
sharifshuvocu19702012
SubscriberI am not using plane wave source.I am using a mode source.
September 24, 2024 at 5:23 pm
SubscriberI want to calculate effective mode index,normalized guided power,propagation distance,surface and bulk sensitivity.and also figure of merit.
September 25, 2024 at 6:47 pm
Guilin Sun
Ansys Employeeeffective index can be found from the mode source;
Not sure what is your definition of the normalized guided power. You can use port to get transmission for each mode you want;
also not sure what "propagation distance" means, since usually it is what you set;
"surface and bulk sensitivity" what are the math and physical defintions? FDTD gives you field components and power quantity. The rest is up to you for calculation from definition;
"Figure of merit" is what you define and calculate.
5934
1306
.png)
